MustRotate
- Aug 24, 2007
Hello folks.
Small networking issue: 20MBps connection,3clients.Router in case is a Linksys WRT54GL with DD-WRT v23 on it. Big problem: it limits the bandwidth for client at 4MBps(wired).
What router should I buy that removes the bandwidth limitation?
D-Link DIR655? Basically I need a real good wired router.
Would a second hand desktop PC(Dell Gx260
4 2.2GHz,256MB ram and so on) be better for the task of routing?
I am thinking on that versus(DIR655 vs PC) because the PC would be cheaper.
To sum it up.I need:
-router with no bandwidth limitation(or above the 20MBps)
-should if possible have the option to limit bandwidth per IP/MAC/port e.g:2premium clients,1low bandwidth
-should be able to handle massive(150+) torrents from max 2clients
Very big thanks in advance for any advice.
