dimensional issues... is there an elegant way to do this?
nodriver
I've found the case I want to start from, and I've got my project in mind. One of the things I want to do is put in a 4x40 LCD, and I've even found one that is reasonably priced. But the pcb is 6mm (almost .25 inches) longer than the case is wide. Unfortunately, it is such that even in the photos you can tell that there will be little to no wasted space on the edges of the pcb to trim down, and with a printed circuit board I'm not sure I'd want to risk ruining it by cutting it down anyway. Any suggestions on how I might be able to make it fit without having pcb and wires coming out of at least one side of the case? I'm willing to consider putting the LCD on one of the side panels as a last resort but I'd much much rather make it work out on the front because of the overall effect and the fact that this case will sit on the floor.. Anyone seen a project where something was done to accomodate a component that was just a bit too big without making the project look like crap? Alternatively, does anyone know of a place where I can find a 190mm wide (or smaller) backlit 4x40 LCD that doesn't cost $40+?
thanks in advance :)
perhaps you could desolder the lcd from the pcb and relocate the pcb?
I'm willing to consider that but I'm new to soldering in general and it doesn't sound like a beginner's project ;) But I've got a dead CDRW drive to practice on so if I get confident I may try this...
maybe you could mount it on the top of the pc... if it has a window the computer will be most likely in a bad angle to see the front.. but the top...
