leezard
- Aug 24, 2004
http://lifehacker.com/5336382/digsby-joins-the-dark-side-uses-your-pc-to-make-money
Yes you can turn it off, but the simple fact that they dont tell you how they plan to use your PC up front (during the install) is pretty shady IMO
You can debate the merits of bundled crapware, and brush away the despicable nature of preying on those lacking adequate tech skills, but did you realize that Digsby is also using your processor to make money?
That's right. Buried in the Terms of Service that almost nobody ever bothers reading, there's this exploiting-the-fine-print gem explaining that they will use your CPU to run distributed computing problems that make them money:
15. USAGE OF COMPUTER RESOURCES.
You agree to permit the Software to use the processing power of your computer when it is idle to run downloaded algorithms (mathematical equations) and code within a process. You understand that when the Software uses your computer, it likewise uses your CPU, bandwidth, and electrical power. The Software will use your computer to solve distributed computing problems, such as but not limited to, accelerating medical research projects, analyzing the stock market, searching the web, and finding the largest known prime number. This functionality is completely optional and you may disable it at any time.
