Digital vibrant question
fatez
I recently updated to vista and installed the 158.19 driver from nvida. However, everytime i restart my computer, I have to go back and manually adjust the digital vibrant to the setting that I want. In other words, it would not save my setting. So, the question is how do I get it to save my setting?
This are my comp spec:
amd 3400
6800 ultra
dell 2005fpw
corsair xms ram, 1 gig
Thank you for all of your input. P.S. It always saved on my setting on Xp, and it also saved with my laptop who have also have vista. Both machine have vista ultimate.
It should just save the settings automaticly. Is there any way to use it in vista? What part of the control panel is it under now?
Thank you for the link, it works like a charm. I'm so grateful to you guys. Whoever knows that such a fix was so easy. A click of a button solves the problems.
