I have a question regarding my on-board Realtek soundcard.
I currently have my sound hooked up from the on-board card optical-out to a 5:1 Yamaha receiver out to my speakers. It works quite well for me. The soundcard can output DDL and Dolby Pro Logic IIx.
Since I am using digital outputs, is there a significant advantage (sound quality-wise) to purchasing a separate card? I would still use the digital output, since the receiver back panel is about 8 feet away from the computer back panel. I would think that the longer optical cable would carry a better signal than longer analog cables, but that is just a guess.
Also, I am using Vista x64, if that make any difference.
