Hello all,
Having kind of a strange problem on a few of my machines. First off, I use Altiris rapidinstall to distrubte computer images to machines. I have alot of machines to look after, so having some require special attention - ie: static IP addresses isn't an option for me.
The image I use seems to work great, I use it all the time on my Latitudes and yet a few that I come accross now when I image them the network card seems to deny that its working - it won't acquire a network address. Now, I know the card works because I can ping localhost just fine, I can receive an image accross the network just fine and if I install Windows from scratch it works fine. Yet when I image a few of the machines the network card just stops operating properly once windows loads, it won't find the Novell server. If I force it in as Workstation only it connects up until the point of Acquiring Network address where it will hang forever. I've uninstalled and reinstalled the card, I've updated the drivers many times - I've pulled the drivers off machines that work with the exact same hardware - and still nothing.
Really not quite sure what's going wrong - the image works on so many of the other machines and I know the hardware works in a pre-windows environment or in a fresh windows environment, but on select machines the image refuses to let them connect (wirelessly or wired).
Kind of at my wits end on this one - since technically if I rebuilt windows these ones as special I doubt dell would take them back as non-working.
I noticed this problem previously with one optiplex machine in a lab. For years it worked fine accepting the image - and yet it suddenly did the same thing I described above with the Latitude series.
I know its kind of an odd and very specific problem, but anyone have any ideas?
