different cooler for my 5850
It should fit the 5850 if it fits the 5870. The thing I'd be concerned about is whether it fits without mods. I know on some heatsinks you have to bend fins or something to get them to fit right. If you end up getting it post pics and let us know how it went. I'm looking for a cooler for my 5850 as well but it seems as though most coolers either don't cool well enough or don't fit properly without mods.
UPDATE: Looks like the reason the TT Pro is not compatible with the 5850 is because the 5850 is shorter and so the DVI shroud will get in the way of the heatsink. Should fit with some light mods...
