Different 280 brands in SLI
MorgothPl
Is it posssible to put two 280gtx from different manufacturers, and that will work? I've the evga SC edition, but they recently went a bit up... so can I buy like Asus (which is cheaper then evga) and pair it with my SC in SLI system? Or do I need to buy second Evga?
yes it will work, the sli clocking will take on the primary card's speed so I've read. I have not tested this as my sli cards are identical - which is the best scenario.
Yes they will work together, but as poster above said, the faster card will have to work on the same clock speeds of the slower card. So if you have a 750 on the SC and 680 on the slower card both will work at 680 (example of clock speeds, dunno the 280SC real clock speed).
I'm not convinced that the cards actually do default to the lower card's stock speeds, although that is the conventional thinking.
I own two GTX 260 and according to Rivatuner, if I leave them at their respective default settings, they operate at different frequencies, at least on the core (576 vs. 601).
In fact I'm pretty sure that the old wisdom is bunk, because I once had a problem where one of the cards (in the second slot) would get stuck in low power mode, and so the SLI performance would go to shit, while single-card performance (working at correct speed in the first slot) would be fine.
Obviously, you can set both cards to the same speed regardless. Before the multi-monitor SLI, though, the overclocks would never stick when you switched in and out of SLI and/or multi-monitor, so you had to keep reenabling the overclock if you had cards with different BIOS-enabled default speeds if you wanted them to run exactly in tandem.
Or you can do like I did, even though both of my 7800GT's where EVGA they had different firmware version and clock speeds, instead of always playing with the clock speeds in windows trying to keep an overclock I went to the firmware level and modded the firmware to both forcing the same clock speeds. I also needed to have the newest firmware on one of the cards cause it was causing issues in SLI mode so to anyone, if your having issues, you might want to make sure the cards firmware is up to date!!
My top card is clocked at 648/1404/1161 default. The lower card runs at it's default 602/1296/1107 in SLI.
Of course they can be overclocked/underclocked to run the same speed by the user.
How did you manage to set the clocks independently of one another? I am interested in doing this, as one of my cards is a significantly better overclocker than the other, but is being held back.
The "master card" set the speed, if it is the faster card or not depends on witch card is put in the "master slot". Thats how it works on the 790i anyway, cant think it works any other way on other boards.
I didn't "set" the clocks independently, I just left them at default. They just happened to have different defaults.
What you could do is flash the card's BIOS, or firmware, whatever it is, to the clock speed you want Rivatuner to identify as default.
Frankly, though, you're wasting your time. I don't think that running one card faster than the other in SLI is actually going to improve your gameplay experience. If anything it'll mess things up as what one card renders goes faster than what the other card does.
TigerDirect sent me a factory overclocked card when I ordered a stock card.
It's why mine show as different speeds.
The cards can absolutely be clocked at different speeds, and the "master" card does not dictate the clock speeds for any others in SLI.
Then explain why a GTX280 Vanilla OC to SC if i have a SC as master and the SC downclock to Vanilla if the Vanilla is master.
I had that perticular setup before and that is the way it was but i sold the crappy vanilla that was a POS on OC.
http://www.evga.com/forums/tm.asp?m=151488
Q = Can I put 2 cards in SLI even though they have different clock speeds?
A = Yes. The way SLI works is that when you activate SLI the driver "looks" at the card's clock speed that is in the primary slot (top slot) and sets the clocks to both cards to that speed. SLI does not permit independent GPU clocks meaning that both cards must be running at the same frequency. So higher clocked card in the top slot = both cards run at the higher clock speeds. Lower clocked card in the top slot = both cards run at the lower clock speeds.
There have been changes with the 180 drivers and gtx260/280.
http://forums.slizone.com/index.php?showtopic=29538
"I have noticed that there has been some concern regarding the GTX 260/280 and clock throttling in 2D/3D applications with the 180.4x drivers. This is normal. Earlier drivers had "Stuttering" problems due to the implementation not being bug free yet. So the feature was disabled in the 17x.xx drivers. It has however been reimplemented in the 180.4x drivers.
However the the clocks/voltages of your card will throttle up and down dependent on how the GPU is loaded. This is a GT200 card feature. Not a bug. It is entirely dependent on how loaded your GPU is. If your in a CPU limited enviroment the card will throttle down for better power/noise levels. If users are noticing stuttering with these drivers. Please post here and let me know and provide the software/settings you are using. "
These days, everything is so close to the reference design, I think brands are more or less who you want service from. Thus I'd not worry at all about mixing brands for SLI or the like.
Mix if you must but... If I was spending hundreds of dollars (and I did) on an sli setup, I wouldn't play the mix and match game. What sli cards have you used? You might be surprised what different brand resistors, caps, ect can do to an electronic signal.
