What are the differences between these 3 Gigabyte X48 boards? Both seem to be exactly the same?
1- GIGABYTE GA-X48-DS4 @ $230
http://www.newegg.com/product/prod [...] 6813128336
2- GIGABYTE GA-X48-DQ6 @ $290
http://www.newegg.com/Product/Prod [...] 6813128331
Why the $60 difference?
3- GIGABYTE GA-X48-DS5 @ $??
The ONLY difference I found so far is 2 less SATA and 2 less eSATA ports on the DS4. Can it be only that?? 3 models with very different prices but exactly the same??!!
And which do u recommend if overclocking is not an issue...neither is a Crossfire setup in mind...would I be satisfied with the P45 performance?
My proposed setup:
One of the above mobos
Q9450
8800GT 512
8GB DDR2 800
2 x 1 Terabyte Samsungs
Vista Ultimate 64bit
Intended for heavy audio video encoding...photoshop...etc...
Gaming from time to time...when I can ....but must be able to play all current games...bioshock..crysis..etc..
What would be a SILENT power supply for this setup...but powerful enough?
Like I said...NO OVERCLOCKING will be done...and I will not use 2 graphic cards...
Thanks..
My proposed setup:
Q9450
8800GT 512
8GB DDR2 800
Thanks..
