Citizen Snips
- Jan 6, 2009
I have been running prime95 for several hours on my new X58 SLI/core i7 920 build and have reached the following steady-state temperatures as reported by EVGA's E-LEET utility (it looks exactly like CPU-Z but also has a special tab for overclocking settings):
core 1: 58.0 C
core 2: 56.0 C
core 3: 58.0 C
core 4: 54.0 C
This is at stock speeds. Is the difference of 2-4 degrees C normal, given that all cores should be loaded equally by prime95? What differences in temperature between cores do the rest of you see under load? I see the same difference in temperatures between the cores at idle.
Is the difference in temperature due to:
1. inaccuracy of the temperature sensors
2. imperfectly applied TIM
3. imperfectly secured HS
4. imperfections in the HS construction
5. all of the above
6. something else
Also, are these sensors on the die of the CPU itself? If so, can someone tell me which core number in E-LEET corresponds to which physical core on the die?
E-LEET also has another temperature sensor labeled "CPU". Is this one located on the motherboard?
core 1: 58.0 C
core 2: 56.0 C
core 3: 58.0 C
core 4: 54.0 C
5. all of the above
6. something else
