Apr 11, 2009 #1 F Fafeifa Gawd Joined Jul 25, 2005 Messages 972 Anyone know what is the difference between these processors? I couldn't find any physical differences from the spec. Itsn't bloomfield and gainestown the same core?
Apr 11, 2009 #2 Â âVelocitymasterâ Gawd Joined Dec 12, 2004 Messages 584 The difference between the w35XX series is their power rated at 130 watts while their e55XX series has their higher ones rated at 95 watts. Also there are other small difference look at their details and models of each series. http://www.intel.com/products/processor/xeon3000/specifications.htm http://www.intel.com/products/processor/xeon5000/specifications.htm
Apr 11, 2009 #3 B Blue Fox [H]F Junkie Joined Jun 9, 2004 Messages 11,813 W35xx = single socket. L55xx/E55xx/X55xx/W55xx = dual socket.
Apr 11, 2009 #4 I ilkhan [H]F Junkie 2FA Joined Sep 23, 2002 Messages 13,955 w means 130 watts, e means 95 3 means single socket, 5 means dual
Apr 11, 2009 #5 S sphinx99 [H]ard|Gawd Joined Dec 23, 2006 Messages 1,206 What is the cause of the power draw improvement? Better manufacturing process? Also, are the W35xx processors essentially identical to the existing i920/940/965?
Apr 11, 2009 #6 I ilkhan [H]F Junkie 2FA Joined Sep 23, 2002 Messages 13,955 better chips within the batch. AFAIK theres no hardware (microcodes are different) difference between the chips.
