Difference Between Two HannsG's
bencho
Hi,
What is the difference between the HG281DJB and HG281DPB?
Are they different panels?
Is the only difference in the stand?
I'm looking for a cheap 28" for movies and as an extra screen [that can go to portrait] and this one seems to be the cheapest. It's currently less than my 245bw, which was $550 when I purchased it. So before I drop $$$, whats the difference? Seems like the DJB is newer?
Other suggestions for a large cheap 1920x1200 would be appreciated as well.
If you are dead set on one of the 28" (actually 27.5 inch) Hanns monitors, I would suggest getting the 289HJB (Hannspree). I believe it is a newer revision. It retails for $399 at Best Buy so it should be fairly close in price to the 281's. There is a pretty lengthy thread here about the Hanns 28 inchers. Do a search for ot and you will more than likely find the answers you seek.
Well im not 100% dead set. I'm just looking for big and cheap at the moment. my 245bw is pretty good for regular use and gaming. I'm looking for a bigger movie screen that's decent. What other 28"s are out there with 1920x1200 that are 400 and less? ALso, there are no review for this HJB version you speak of :\
