-http://www.allaboutcircuits.com/vol_6/chpt_3/7.htmlPotentiometers find their most sophisticated application as voltage dividers, where shaft position determines a specific voltage division ratio.
The ideal situation would be an LM317 or similar part with a potentiometer on the adjustment leg. Just the pot in series with the fan ought to do something, though. Are you sure it rated for the current the fan pulls?Originally posted by awdark
Hrmm I know I can dig up some potentiometers.. does anyone know why I usually end up with smoke when I try to reduce the voltage of something lets say a fan with a potentiometer?
If I follow the basic ideas of that site above about Potentiometers it is suppose to work right? or will I need a voltage regulator in combination with that or something of that sort?
