Monkeypillow
- Aug 30, 2006
The only thing that stands out is that one contains the NF200 chip, while the other doesn't. Is this the only significant difference, or is there more? If it's just the NF200, I'll save the money.
Essentially, the "original" Classified, like I have, has the NF200 chip, a little daughter board called the ECP (Evga Control Panel) and a "Limited Edition Certificate" (BFD).
Thats really it. Other than that the boards are identical.
I use SLi so the NF200 is wasted on me, but it was all there was when I stepped up.
I really like the board. It has been solid right out of the box......but if you don't need all the schizzle............get the "plain" X58 SLi board. I had one of those, and it was very stable and allowed me an OC right at 4 GHz on a 920. On the Classified I've made it to 4.15 GHz with the same cpu..........basically I think its the cpu and not the board......I'm considering a D0 version.
Which should I go for?
If you really want a Classified, there is just one question to answer......
Triple Sli.
If you ever thought about Triple, get the NF200 model.
If it isn't an issue, get the nonNF200 model.
enjoy.
It a great board.
Only advice, get a small 50mm fan for the NB heatsink. The NB tends to run a little hot and the fan makes a big difference.
I used this one:http://www.frozencpu.com/products/6...ow_50mm_x_10mm_Fan_125010DM.html?tl=g36c15s71
I don't think it really matters all that much......all these little ones make noise......the width is the real key. 10mm is about all the space you have to squeeze the fan into place.
I decided to use water and bought the BitsPower block..............it was mad expensive, but I just threw caution to the wind.......and a fistful of cash.
4500 RPM .
I can't even hear it above my case fans,GPU fans,PSU, and sound.
EVGA just announced another two X58 boards today to get thrown into the mix...
http://www.xtremesystems.org/forums/showthread.php?t=225082
You had me scared for a second. I thought they were superseding the Classified.
edit: That seems like pretty crappy placement of the 8-pin ATX 12v.
Its actually so that people dont have to get 8pin extensions.
Oh, okay. I was looking at it from the viewpoint of someone routing the cable behind their motherboard tray.
Holy shit that Micro looks fucking awesome! Maybe I won't buy a BR after all! I kinda wanted the SAS ports, though. :lEVGA just announced another two X58 boards today to get thrown into the mix...
Wait, I thought you got the BP block?
Yes, I did.
I haven't had the time to install it yet......maybe this weekend.........have to take the board all apart.
In reference to the new LE......how would that 8 pin placement keep one from needing an extension???? In that location (lower) if your PSU in top mounted, you'd almost NEED an extension to reach.....meh.
I do like the look of the LE overall.
But now there's no way to really hide the wires well. :L
