I have an Asus Sabertooth motherboard and it has a Marvel 6.0Gbps controller on it. I currently had a hdd plugged into it and I'd experience Windows freezes once in a while, usually coming back from S3 sleep. I finally re installed Windows and figured out it was NOT Windows causing the problem. I investigated and think I found it. I have several SATA cables I just throw in a box. Some are red, some are yellow. I had a red SATA cable connecting the Marvel to an Intel SSD. Using Drive Fitness Test, it occurred to me that the Marvel controller didn't like those red SATA cables where as the Intel 3.0Gbps controller thought they were fine. Is there a speed rating or difference from cable to cable? I always figured they were the same.
