difference between saphire 9800pro and built by ati 9800pro
xbreaka
My friend claims that the built by ati runs off a different core than the saphire, hes says the saphire runs off the r350 and the built by ati runs off the r360, is there really a difference or is my friend just retarded
Nah, dont mind xbreak he just has bad auditorial skills..and didn't listen that what i said was with the saphire version of the 9800pro...when you look under the hsf it is imprinted with r360 which is to my understanding a 9800xt core..and yet its a 9800pro setup. hmmm :confused:
saphire builds most of the bba cards, plus all 9800 pros, non pros and SEs use the r350, the r360 is the 9800xt, and even then the only difference is a temp sensor on the core.
I have both cards in the 128 meg version.
The board layout, look, sticker location, core (r350) is all the same.
The Built by ATI has a better warranty :D
If i am not mistaken, Sapphire makes the Built by ATI cards for them.
Some of the OEM cards have lower clock speeds, and even some of the Retail from other manufactures vary too.
I got a sapphire 9800pro just in from newegg yesterday, and im lookin at this core and it says r360...lucky me i guess.
the r360 is probably all they make now, they just speed bin it. the r360 and r350 are for all intensive purposes identical
This seems to have everybody confused.
The original 9800 pro core was the 350. The XT core was the 360. Sapphire has started selling 9800 pro 256mb cards that are just underclocked XTs, so they have the 360 core.
This is the only case of an XT card being sold as a pro that I know of. Otherwise all Pros are 350 cores.
the 128mb pro i bought has the 360 core, :D lucky me. And concidentally many others who are purchasing the card now are having the same luck, although unfortuneatally many may not take advantage of it.
Such as my friend who was bragging to me the other day about how he just got his 9800Pro and how much better halflife runs (he upgraded from like a ti something. god i hate rich people.:mad:
Sounds like they're really getting lazy now. Is there a bios for a 128mb 9800 XT using an actual 360 core?
Did you have to pry off the heatsink? If not, is there any other way to find out what core you have?
So, Sapphire Radeon 9800PRO 128MB card that you bought was r360.
Great.
Now, which card of these was it? Retail, OEM or Bulk.
Thank you...
the new sapphire cards are using R360 core yet they are being sold as a 9800 Pro. You can flash them to 9800XT speeds.
The 9800 Pro 256 mb sapphire is actually a 9800XT flashed to pro speeds.
Lastly, BBA cards run the right cores, R350 is 9800 Pro and R360 is 9800XT.
According to some user reviews on newegg, some of the asus 9800 pro 256 cards use the 360 as well.
