Difference between Plus and non-Plus Silverstone SST-ST50EF
GilmourD
So, what's the difference? Just the efficiency? I don't see a whole lot in the specs.
One is made by Etasis; one is made by Enhance. Big quality difference.
Ah... OK... I was already stretching my conceived budget thinking about the non-plus model. I'm going SLI with two 7900GSs and wanted something that was a bit overkill since I'm also OCing. Hmmm...
Actually, I think it's the Plus that's the enhance and the non-plus that's etasis. The etasis isn't 80+.
why not pick up the Silverstone ST60F strider from newegg, they're really cheap. Better yet, deadeyedata has a discount for members of JonnyGuru forums on silverstone power supplys. Killer discounts.
the plus models are made by enhance and the non plus are etasis. both are very good oem's though so i wouldn't worry about a quality difference.
Considering that I'm OCing and eventually going to have two 7900GSs (or possibly another card), what would you rather go with?
