Sep 27, 2005 #1 V V3|!UM Limp Gawd Joined Jun 25, 2002 Messages 461 As the link says i just ordered an MSI Neo4 SLI, does anyone know how much better or worse the onboard sound is then an audigy 2 ZS? is it better to just use the onboard or is the audigy 2 still the better pick?
Sep 27, 2005 #2 Z ZigZagZeppelin 2[H]4U Joined Nov 29, 2000 Messages 2,307 Never use onboard sound, it uses up cpu cycles slowing your pc down. Audigy 2 ZS will also have higher quality signal to noise.
Sep 27, 2005 #3 V V3|!UM Limp Gawd Joined Jun 25, 2002 Messages 461 you do understand that the onbboard for this mobo is the SB live 24bit right?
