difference between NF2 400 and NF2 Ultra 400?
it will work fine with you agp 4x card. no worries.
Interesting question about the 400 vs 400 ultra, I would have thought the ultra would have had a simple SATA drive port on it but that one doesnt. So have to give that question a /shrug.
the 400 ultra supports dual channel the plain 400 does not. and the shuttle will work with your 8500
That is not true about the NF2 non ultra not supporting dual channel... I bought an Epox 8rda+ NF2 400 chipset motherboard the first week they were available and it ran dual channel just fine..
first off the 8rda+ is an ultra 400 chipset. second i said the non ultra 400 doesnt support dual channel not that it cant run in dual channel. for instance if you take an a7n8x-x and put a dim in slots 1 & 3 memtest86+ says your running dual channel. Some of those boards work fine in dual channel, and some like the one i have on a testbed (note this is the second a7n8x-x in that testbed and neither will work in dual channel) will fail with thousands of errors if you try running dual channel with it. thats why i said it doesnt support dual channel, not that it cant run in dual channel.
Errr....not *quite* right still.
What the nForce2 Ultra 400 supports that the 400 doesn't is 400mhz FSB. The 'regular' 400 supports 400mhz ram, but you have to run it out of sync with the FSB, it only supports (officially) processors up to 333FSB.
The Ultra 400 supports 400mhz ram and 400mhz FSB, so you can run them in sync. (Although, FWIW, I'm not aware of anyone with the 'regular' 400 who couldn't run 400FSB, anyway - even if it wasn't officially supported. That said, FSB overclocking OVER 400 is probably harder on the 'regular' 400 board.)
The other difference was that early nForce2 400s could only support dual-channel at 333. So, the FSB was maxed at 333 on them, and the ram could only do dual-channel at 333. If you took the ram up to 400, it would be out of sync with the CPU's FSB, and it would be single-channel.
Although, I'm 99% sure no boards actually went to market with this restriction - IE., they weren't SUPPOSED to be able to do dual-channel at 400, but all of them do (and those that don't have the ability just one BIOS flash away).
If I were in the market for an nForce2 board again, I'd go Ultra 400 in any case.
NF2 400 (non ultra) will run 400/400 in most cases just fine without any voltage tweaks at all. I have set up both the Biostar and Asus versions with XP3200 with PC3200 (4 Biostar and 3 Asus) with so much as one problem. Also, the older crush 18d chipsets even though limited to 333 DDR even though it would accept a 400 FSB processor does not default to single channel 'because' it is running async @ 5:4 (or 400/333). Still runs dual channel though obviously loses some memory bandwidth due to being async.
I'm not confused at all. After the Asus and Biostar boards, and about 82 other NF2 boards built (shop) of other makes, and stickies posted about NF2 at 2 other forums, I know NF2 backwards and forwards. I was building the crush18d boards when they first came out also (the non-ultra epox 8rda+ boards and asus-abit rev 1.2 boards) - some of which were upgraded to 400 FSB support with a bios update, but they were always dual channel. I also understand the NF2 400 "nforce2 400" (Like the Soltek NV400 L64 and the Asus A7N8X-X, and the Shuttle AN35N400 are single channel. I have built those as well. I understand the detailed differences between Crush 18D, NF2 400, and NF2 Ultra. down two the MCP, non MCP, and the actual sound codecs of every single NF2 board made from ALC 650 to ALC655, to ALC 850, to CMI 8738, including Biostar knock offs to Jetways, to XFX, to Mach Speed (made by Azza which also makes XFX).
I know that the only nforce2 boards that were ever single channel were the nforce2 400 chipset boards. When you say " Only the ultra officially supports dual channel" you are wrong. The early Nforce2 regular (crush 18D) boards were also dual channel. I have a Biostar M7NCG 400 right now that is not and ultra board - that IS "officially" dual channel. It's still sold as crush 18d, but "supports a 400 FSB barton, but will only "officially" run mem @ 333 FSB. Revisions 7.2 will run mem @ 400 Mhz with a slight vdimm bump.
What you should have said is that the ultra boards are the only ones that "officially" support memory speeds @ 400 FSB. Nearly all will however run a 400 FSB processor. But they all (besides the Nforce2 400 boards like the Soltek NV 400 l64) run dual channel...."officially". Even if @ 5:4 ratios.. It's still dual channel.
FYI, I have an 8RDA+ that is NOT an Ultra 400 chipset and it DOES support dual channel. I have been running dual channel for about 18 months with this board. The non Ultra NF2 chipset does support dual channel. It sounds to me like your ASUS board is defective.
first off zone i was only comparing the 400 and ultra 400 in that statement as that is what scubasteve was wanting to know what the differences between the two boards are and they are an ultra 400 and a 400. second to 7th angel according to epox the 8rda+ is an ultra 400 chipset and that is what i based my info off of. also the asus board is not defective it has been repeated many times in the rma testing of the company i work for. And yes the spp and ipg nf2 support dual channel. but as i said before the 2 boards he wanted to know about are ultra 400 and 400
It's cool. I'm sure we just kind of misunderstood each other anyway. More so I think I misunderstood you in that you were comparing the Nforce2 400 only to the ultra 400. The nforce2 400 will never run in dual channel under any circumstances though. The Nforce2 400 boards tend to be more stable overall. If only slighly so. They tend to get higher 3D marks, but lag slighly behind in specific memory bandwidth intensive tests. If one does not plan to overclock the Biostar M7NCD Pro or Shuttle AN35N Ultra are both super stable, although they don't have SATA or MCP-T. The Asus A7N8X-X seems to be a very stable Nforce2 400 board. For just a plain good running NF2 board with the basics I would get the Shuttle AN35N ultra and get matching sticks of mem and use the little extra dual channel bandwidth advantage. The shuttle AN35N's also play with with mobile processors and overclock very well.
Regards
