difference between I5-2540M and I5-540M?
cifroes
Hi,
I'm a it away from the "hardware" scene, so i'm not upto par about these new cpus. Both are mobile versions and it seems the difference is sandy bridge vs Arrandale.
So what the differences between the two?
Should I get the i5-2540M or the performance isn't very different?
Also if you can provide some graphs showing the performance diff, I woul'd appreciate it.
thanks in advance
ya SB without a doubt you can see in link cifroes posted the SB one wins in every case.
The difference between these two processors really comes down to the advantages that the 2nd generation Intel® Core™ processors have over the 1st generation Intel Core processors. At the same clock speed the Intel Core I5-2540m would outperform the Intel Core I5-540M by around 15% to 20%. Also the Intel Core I5-2540 would have the improved Intel HD 3000 graphics giving better graphics performance when using those graphics and a host of other features that can be seen here http://ark.intel.com/Compare.aspx?ids=43544,50072,.
