Cypher19 said:It's just double the bandwidth between system memory and the GPU, which doesn't affect many games to a large extent, last I checked.
Ocean said:"Personally I would save up and make the PCI-e/ddr2 jump if I were you.. in the long run you would see a TON of performance hike, since the total system memory bandwidth is increased as well as expandability options with PCI-e cards in the future."
yep time to upgrade your core system.
it would be a waste for you, at most consider a 6600gt (sideways movement with sm3), and just hold out until you buy a pci-e system.
your power supply would likley bottom out, and 7800gs is longer than that mobo, lots of risks for your system,
save and upgrade, save and upgrade.
