Originally posted by MotionBlur
Less Power consumption meaning higher overclocking
Originally posted by DaveX
Not necessarily. So you're saying the mobile 2500+ can reach the same FSB oc's as the desktop 2500+? I doubt you could push the mobile 2500+'s 133 FSB to the typical 220 FSB oc on the desktop 2500+. Lower voltage won't necessarily allow more oc room. Maybe the mobile 2500+ can take less voltage than the desktop 2500+.
I never said they were bad ocers. I am merely challenging the fact that they are better ocers than the desktop version.
I hate it when people gripe about the locked multipliers and then go buy a Mobile 2500+ just for that sake.
Originally posted by md262626
Wouldn't the Mobile 2500+ be the better processor because of the potential better o/c'g due to the unlocked multiplier?
Originally posted by Deliximus
2500+ mobile and desktop version do not run at the same Ghz.
Must be some confusion (on his part) as the mobile does run 1833MHz, but differing from the desktop counterpart in the FSB where the mobile is at 133MHz (266DDR) and desktop at 166MHz (333DDR). The extra bus is what affords the Barton an extra 100 PR points aside from the 256KB more of L2, so if this were officially a desktop part it'd be a 2400+ model but I'm guessing AMD considers it to be faster than the mobile Athlons so it can tweak the PROriginally posted by hyperluminescent
What does that mean. Aren't they both 1.83 stock?
i just went to newegg.com and their part listing is weird. the 2400+ mobile is rated at 1.93ghz while 2500+ rated at 1.83ghz. same fsb, same caches. i'm willing to bet they mixed them up.
http://www.newegg.com/app/ViewProdu...frcode=0&propertycode=&propertycodevalue=4181
My savior! That makes so much sense I am blinded by itOriginally posted by Banukab
As far as the mobile's becoming locked, that won't happen. The reason i say this is due to the nature of the platform a mobile has to be multiplier unlocked so that when on batter power it can reduce the processor speed without affecting other components. It also lowers the voltage as it goes down, which is why there are some conflicts in what the stock voltage is. The XP2500+ for example goes between 1.25v on the low end up to 1.45 running full speed. AMD calls this SpeedStep I believe?
So guys now that you've hijacked my thread can someone who knows recap the differences I originally asked for?
Originally posted by CypHill
Uhm.. no.. Did you get this info from Newegg? :/
Originally posted by Roberty
Quick question - Will any motherboard that will run a Barton run the mobile chip as well or is there a bios issue to deal with like the old K6-2+ and K6-3+ cpu's on a desktop socket7 motherboard had?
Does anybody know if the Mobile 2400+ is as good an overclocker as the Mobile 2500+? NewEgg lists the 2400+ as being in stock now for $79
Like I said earlier, I'm hitting 2.3ghz on my Mobile 2400+ I wouldn't call that bad at all.
