Dieing Antec SP500 fan
iceTraxX
I have an Antec SP500 (ATX 2.0) powersupply that has served me well for about a year and a half. I recently noticed increased noise from my computer, I thought it was my e6300's stock heatsink (which I'm replacing soon). After some investigating, I found it coming from my PSU. I took my PSU apart and found the internal inlet 80mm fan had a blown bearing that was slowing down the fan and causing annoying audible vibration sounds. Does anybody know where I can get an exact replacement for this fan? I can't seem to find one, the model number is RDH8015S and its made by Xfan (in china). If I cannot buy a replacement fan, does anybody know of a similar fan I can use?
_Korruption_ said:
The SP-500's intake fan is 80x80x15, not 92mm as you mentioned.
Your right :) I was comparing the fan to a stock AMD HSF while I had my PSU disassembled and mistakingly thought the AMD HSF was 80mm. I havent used 80mm fans in years, 120mm ftw! I'm gonna see if I can find an 80X80X15 fan now. ;)
I think I'm going to order the evercool EC8015M12CA. Has anybody used this fan before?
The best thing you could do s RMA the PSU. It should have a 3 yr warranty
or hold on... did you void the warranty by opening the PSU?
