Hello
The case will use a mini itx motherboard, mini itx gpu and an flx psu. There will be place for two ssds and one regular sized hdd. airflow will come from two 140mm fans in the top and bottom with passive exhaust from the sides. There might be enough room for 4x 40mm fans below the motherboard next to the harddrive.
Since I'm not that great with SketchUp yet, this is as far as I have come. (What programs do you use?)
I dont know if the dimensions I've found for the mini itx gpu is with or without the pcie connector, so I'm not 100% sure if this placement of the gpu will work.
There should be enough room for cable-management behind the psu and around the hdd.
Does a similar layout already exist?
Thanks for reading, I will update this post as soon as I have more to show you.
