didn't expect this...
u2slow
A friend of mine was having some computer problems. I visited to check it out, and decided I better take it away with me for more serious attention. It ran, but it was pretty slow. Also seemed like settings wouldn't stick, and software wouldn't load properly until the 2nd or 3rd try. Weird, huh?
I discovered it was a P3 running at 366Mhz. :confused: Okay.
Popped the cpu out to see what it really was... its a P3-733Mhz :confused:
Cranked up the speed in the bios, and gave it a whirl. Hmmm.. Spontaneous reboots halfway through booting Windows. :mad:
Did some more looking around.... this is what I found:
desrin said:
Can you just replace those?
You can but I would wonder if it is worth the time and energy. If you end up having to order the caps to replace then prob a solid no. I use to do caps on motherboards for people. I stopped because in many cases you can replace the board for less the 50 bucks. If it is a non standard board or a server board or something I still will but for a 733 p3 I would say trash it.
Yep, swelled/burst caps were an issue a while ago. Abit and a few other mobo makers had problems with it for a while, then a lot of their boards started using only Rubycon or other well known and trusted caps. I don't think it's an issue now. I don't think there's much you can do except replace the mobo. If it's in his budget, get him to upgrade to a nice E6300 combo... ;)
I hadn't come across the capacitor issue until now - I have a few P3 boards too. I may replace the caps if I end up needing one with an ISA slot :p
Upgrade is inevitable. I'm setting him up with a MSI K8NGM2, 2.2Ghz Venus, 400W PSU, 1GB ddr, and a 160GB sata Barracuda. That's 3x the speed, 8x the ram, and 10x the HD of the old P3. ;)
Yeah, so are the dell gx270's... good thing my company got the extended warranties, otherwise we'd be out a whole lot of money.
Though, it's not exactly the highlight of my day when I have to replace a whole motherboard, and just the mobo. cpu get's transferred, along with heatsink... oh yeah... tons of fun when you got 4 to do one after the other...
I've had to install a few motherboards in gx270's. Hell did one about 3 months ago for that issue. The good thing is they are not too bad to get the motherboard out of. I have a compaq d530 sff sitting here that hp is sending me a motherboard for because of bad caps. I'll tell you this thing looks like a bitch to take apart.
Yeah, a gx270/260 should take less then 10 minutes to swap a mb. Much easier then an hp or gateway of the same time frame.
