Did the lightning storm kill my PC?
The Red
Ok guys, I live up here in NY and yesterday we had a big lightning storm at night. Naturaly I turned off my PC while everything was working perfectly without a hitch for weeks. I woke up to my PC not booting. During the night, the lights did flicker, but we did not lose electricity... as supported by none of the clock I have resseting themselves as they do when we realy do lose electricity. To boot, I have my PC and all perepherals connected via a surge protector. Except for the DVi-to-HDMI cable that goes to my TV which does not have a surge protector..
I have an Abit IP-35 Pro with error code numbers, but I cant find a refference ANYWHERE as to what ANY of them mean. While trying to boot up the lights on the mobo are on, the fans spin up, and 90% of the time there is no beep, in the 10% of the time that there is a beep its either two or three beeps. The errors on the error-code readout on the mobo either show 83, or rarely an 87 while the mobo keeps trying to reboot. It keeps trying to reboot, fans spin up then stop, spin up then stop...etc..
What should I try to do here? ... no beeps tells me mobo death, but then it sometimes does beep, and the lights on it do come on every time, and I just cant explain why it stopped working even though everything went fine during the storm.
Any suggestions?
Take it apart and put back together to make sure its not a bad connection.
Its very possible lightning has caused some damage, it can come down aerials, through modems and through the mains.
Mains suppressors might only protect you partially from lightning but they are so cheap you should use one.
If I am near my PC when a thunderstorm approaches, I always unplug it from any potential lightning sources to be safe.
Ok, i'm going to begin complete diss-assembly... in the mean-time, any and all more suggestions for identifying what went wrong would be greately appreciated from anyone!
I really think that you lost your power supply.
worst case the mobo.
but nothing else , start with the PSU
I hope you're right!
I'm almost done diss-assembling, I wonder if I should take out the mobo from the case and re-seat the CPU, but thats like another hour of work... hmm..
Ok, i've done both, removed all the parts from mobo to reseat them, and I've put in a new power supply. There are no beeps coming from the computer... the fans just spin up and then stop spinning.. and continue to repeat the process.
so I guess my mobo IS fried :(
I'm just a little worried about my decision, if there is more than one part to RMA i'd like to know now... after replacing the PSU to no change, I came to the following "conclusion".
Let me just be clear with the assumption I made... "If there are absolutely NO beeps what-so-ever 98% of the time you're trying to boot, it is deffinately a motherboard problem!" ...
My years of hobby experience tells me this is logical... but could anyone offer me up some exceptions?... Quake Wars is almost upon us and knowing that I wont have a PC on release is kind of heartbreaking considering that I'm a huge quake fan and had been beta testing it for months on end... the stars (or rather the clouds) had aligned against me this week I'm afraid...
No beeps. Do you have all the memory out? Do you have a PC Speaker attached? Is it CPU, PS and MOBO?
I found the POST code of 83 as "Save all data in stack back to CMOS" - I found it in the POST codes in section 5-1 of your manual.
what does that mean? ... plz dont tell me my CPU may be compromised too... but I think the Award bios still makes a beep if the cpu itself is the problem... dont it?
Speaker was attached... 98% of the time there was no beep, but rarely there was 1 if I held the power button itself down... a rapid beep. Or a super rare 2 beep, then delayed 1... I think that happened twice ever in my 50 attempts to boot.
PS was replaced with new one and it did not solve the problem... which left me with thinking it was the mobo... but are you really saying it could be my CPU as well? (that would suck the balls)
