Did my harddrive fry?
sublim3
About a week ago i smelled a strong odor coming from my computer, and within hours, it died. I found that the source of the odor and problem was my power supply. I ordered a new powersupply and installed it today. Computer now tries to boot back up, but gets stuck when the bios is trying to detect the IDE devices (my HDD and CDrom).
When I unplug my HDD from the IDE, the boot sequences gets past that, tries to read the CD-ROM, then of course fails. This is why I think my harddrive has fried possibly as a result of the powersupply failure?
Please give your input, I would like to order the part I need asap!
Win XP Pro
XP2600+
Epox 8RDA3+
WD 7200 rpm 80GB
If additional info is needed to help figure this out, please let me know and I'll post it.
Thanks
Put the hard drive in another computer and see if the bios detects it. If it does, it's a bad motherboard, if it doesn't, then it's probably a bad hard drive.
I don't have another computer to put it in...this is a laptop I am typing from...any other suggestions?
Also I just replaced this mobo less than a year ago, the HDD is about 2 years old.
Thanks
Try switching what channel the hard drive is on and see if it still fails to detect.
If I let the bootup process sit for about 5-10 minutes while trying to detect IDE, it will finally see both my HDD and CDrom correctly, but gets infinitley stuck after during the SATA/RAID check which I have none of.
The main reason I thought it would be my HDD besides the fact that when I pull its IDE cable out of it, it tries to boot normally (fast)....is the fact that in the bootup sequence it doesn't sound (the grunt), it made the sound the first couple times I tried it, but not since.
Thanks
Ok I found an old HDD I had and tried it...and it booted up with that one just fine. I guess my PSU did take my HDD with it when it fried, what a bummer.
Thanks for the help -
