notalent420
- Aug 15, 2004
Hey guys,
I have an interesting problem. I was playing Left 4 Dead and then after quitting out I get a blue screen of death. I was in a hurry so I wasn't able to record what it said, although in hindsight I should have. It started to reboot but I just shut it off.
I came back to it an hour later and tried to boot it up. It was taking longer than normal. It would detect my SATA DVD burner but it would get stuck on detecting the hard drive. A few seconds later it would say "DISK BOOT FAILURE. INSERT SYSTEM DISK AND PRESS ENTER"
I tried everything from swapping the ports with the DVD burner, still the same result.
Going into the BIOS, it says something is in the port the hard drive is plugged into but it doesn't list it. I switched it from AHCI to IDE mode, same problem.
The only thing I haven't done is try to plug it into by previous computer. Hopefully it didn't die because I've barely had it for a month.
Thanks in advance
Thanks in advance
