Did I mess up SATA mode
eagleknight
I am running a Gigabyte X58A-UDR3. Did I set this incorrectly when I did the install of Windows 7? I am running a SSD and installed Windows 7 with these options. I changed the Native mode to Enabled now and Windows boots fine, but should I do a fresh install again? :confused:
ICH SATA control mode = AHCI
SATA Port0-3 Native Mode = Disabled
Is your SSD plugged into ports 0-3? If not, and I'm betting not, then the drive should behave the exact same. What this means is it makes no difference if you don't have drives plugged into those ports..
Native mode means the SATA HDD will run as an IDE drive. It was a necessary feature with Windows XP since there were no native drivers for AHCI/RAID.
Oh, and I mean this in the nicest of ways, RTFM! :)
I have it in SATA 0. Maybe I should install again. I did read the manual just understanding it sometimes is the problem. ;)
First switch it back and if it behaves fine then i wouldn't worry about it. No point in wasting time with a reinstall.
The reinstall is necessary because the boot device changes and Windows doesn't have the drivers for it, so it just blue screens. Since you can't boot with the device in that mode, you can't fix it. You need to do the reinstall (or the reg hack) to get the proper drivers installed for the device it's trying to boot from.
If it will boot up, you don't need to reinstall.
This is incorrect. This link is what the description means to be native for a controller: http://www.microsoft.com/whdc/device/storage/Native-modeATA.mspx
If the BIOS option is changed to standard then it will be in legacy interrupt mode, cannot share, and cannot have more than 4 devices to be attached, technically speaking. Back in the beginng of SATA people would say the controller had "native drivers." Most of the first SATA HBA were for SATA RAID controllers only. When they meant native they meant it had support out of the box and did not need to have drivers installed via the "F6" method. This was a problem because it created this little mess up.
With some BIOS you can be sort of be correct in what mode it will be. Some if set to enhanced will be in AHCI mode only or configurable to RAID mode. Anyways I think the link answers the question and clears up the disconcerting issue about native mode.
Good to know! I thought it actually somehow emulated IDE, but your explanation makes a lot more sense.
