Did I kill my MB? k7s5a
crazyjeep
Hey, I got a k7s5a, and well, trying to make it go faster so I can play doom 3, I have a 1800+ AMD, and a k7s5a. I flashed using Honey's latest bios overclocking dohicky(starting simple first), anyways, goes through the bios update(done it before, so i didnt screw that up), anyways, I reboot, and nothing, my cdroms are getting power, as they are trying to read, like on boot, but repeat, and I cant get nething from it. What do I do to fix this? Anything, would be appreciated. Thanks
Also, if it is screwed, what would be a good motherboard that wouldnt cost me alot to buy that I could use my 1800+, and upgrade later with a better processor, all the while that will let me overclock her a bit. Thanks.
All I did was flash,nothing else to the computer btw
CrazyJeep
update, just cleared the cmos, got it up, giving me error, Battery Low. Gonna try and get it up and going, also, what is the best recommended OC rates for my machine? Thanks
CrazyJeep
K7S5A were notorious for poor quality CMOS Batteries. Not to worry though, you can replace the Cmos battery with a CR2032 if I remember right. No matter what model it is though, you can find it at radio shack cause I know they have the CMOS batteries.
With regard to OC'ing, if you have one of the later revision K7S5A pro Ver5.0 or what not, then you may be able to adjust the processor speed to 166FSB assuming your ram is PC2700 or above and also assuming you have VCore voltage control in bios with your latest bios, and that your 1800XP is a TbredB and not a Palomino or TBredA core. If you are lucky enough to have equipment that meets these criteria, then you may have a shot at getting that processor OC'd to a 2400XP speed processor. If you try to OC to a 2400XP please be sure to set your divisor (if thats an option) to 1/5 so you don't OC your PCI and AGP Bus (something that is sure to cause a no post situation). Also, if you increase the Vcore voltage on the processor, make sure you are using a better cooling HSF than the stock Retail one that ships with AMD processors.
More than likely, you will not successfully OC that motherboard at all, the K7S5A is firstly an OEM board and not designed really for OC'ing of any kind, and Second, is based on an SIS chipset which on the AMD side has never been good at OC'ing anything ever.
Good luck to you though.
Ok, this is what I have done yet so far! :) I got it to boot, YEAH!, and I set it to 138/138, she boots to a 1900+ amd. So, I got what, an extra 70 mhz? I need to find out what kind of ram I have, i have 512 mb, but no clue what kind, if it is 2700. Also, I know I dont have a version 5 motherboard, And I know it prolly isnt too keen on overclocking. Now I am debating about buying a new chip to go with my board, however, I understand the board sux. So would I be better off at getting a new MB instead, and overclocking the chip(1800+). And since I am new to the OCin world, any suggestions on a budget mb? I got about 100-150$ to work with, I am trying to get my machine decent enough to run doom 3, I got a geforce fx 5200 agp. I have yet to tweak any of the ram settings in the bios, and might do that tonight, if I am lucky I might be able to squeeze out some more speed, the question is, Anybody else trying to have done what I am doing now, and how fast can I get my chip to go with the MB i have, or another board. Thanks
CrazyJeep
