Did I kill it?
FRZ
While playing shogun 2 last night my computers power went out and after restarting the ssd raid array had failed. After letting it sit overnight with no power plugged in and a CMOS reset I was able to get one back online, but the other drive is still missing. The raid 0 was between 2 100gb ocz vertex limited editions. Is there anything else I can try and do to save my drive or is it rma time?
Thanks in advance.
Running an Asus rampage 3
u could also try replace the sata cables and ports on the mainboard if possible i had the same problem power went out and the raid failed i changed sata cable and mine was fine
u could also try plug the one that doesnt come up into the sata cable of the ssd that does come up could be a problem with the board the sata cable or the ssd itself try illiminate those sort of things
