1. Did i hinder my system by adding another PC2700ram 256mb ram stick to add to 512mb i had? 1x512, 1x256= 768mb VS 1 stick 512mb = 512mb?
2. How big of a difference is lets say 1 stick of PC2700 to a 1 stick PC3200 stick? 333mhz - 400mhz will it really boost performance THAT MUCH?
3. Can someone here elaborate on how to run dual channel ram..my mobo has 4 slots 2 blacks 2 whites. if i want to run dual channel i believe i need 2 sticks with same mb for example 2x 512. but can i just stick them in any slot on my mobo or it has to be set specifically?
4. Ati Radeon 9700 Pro VS nVidia GeForce FX5900nu
5. How do i get 75Hz refresh rate on my 9700pro at 1152x864. It won't accept it goes back to 60Hz. Now in any other res it works fine at 75Hz like 1024x768. Yes, i have installed my specific monitor drivers and Yes, i have done the registry tweak where windows xp sees only 75hz instead of the default lock on 60hz. I use to get this fine on my old FX5600 card why not my 9700pro?
6. Which would give me a BIGGER performance boost? going from a 5400rpm hardrive to a 7200rpm? Or going from DDR333 to DDR400?
Thanks in advance guys!
