Hello guys,
I've just built a new computer, and this was the first time I've used ESD protection like wrist strap and grounding mat. Now, I believe I have used these tools to the best of my ability. But when you do this for the first time, you notice that nothing ever goes as you intended, nothing is perfect. Even though I am quite confident about the way I installed everything, I am concerned about something I did during the installation.
Before I knew that adhesive tape is bad for electronics, I used to tape together the wires of my 80mm fans to keep my case orderly. Yesterday I removed some of this tape from those wires to play it safe. After removing the tape, the wires were a bit sticky (or better said, their insulation) so I used the tape over and over on the wires to get the residual glue off. Unfortunatly I only later realised that the wires of the fans were plugged into the motherboard via two Zalman Fanmate 2 regulators. I immediately panicked and stopped with what I was doing.
I might be overreacting, but I don't know enough about electronics to be sure. Could I have damaged my new setup by this? To be clear, I used the tape on the (red, yellow and black) insulation of the wires to keep them together and each wire was connected via a fan regulator, which probably has a resistor built in, to a motherboard fan connector.
I realise that insulation should, well "insulate" the wires but will it protect the wires from the static charge created by the tape? If not, what about the Fanmates? I believe they are set to run 12V fans at about 7-8V right now, could they have offered some protection perhaps?
