Did I damage my mobo?
I was trying to install a zalman fan onto my ep45-ud3r mobo and I was trying to force a screw in and I didnt realize that it was screwing directly down on part of the board. This is the damage:
See how the middle one looks messed up? Thats the part that it was screwing down on. I am not sure what this is called. I know the pic isnt very good.
Will this damage my my mobo?
It's a capacitor, it's part of one of the power phases for your processor. It might still work, but if it doesn't it might damage your processor, and if it does you'll have to foot the bill for a new board and chip as it's pretty obvious the damage is entirely your fault. Good luck.
If the damage has caused a short circuit on the capacitor itself, you could be in for some problems. You could try using a multimeter set on ohms (resistance) scale across the 2 solder side points of the cap and compare it with the other caps.
Unfortunately, this may not give you an accurate reading as there are plenty of other compontents connected to it that might give you false readings. The only way to be sure is to remove it from the board and test it isolated (and while you have it removed, its worth replacing anyway).
If you want to chance it the way it is, if you have a non-expensive PSU and / or CPU laying around, I would be testing the MB with these first before I used my good components.
I interpreted the picture wrong, sorry. Does look like you dinged up that cap quite good. If it's damaged you might experience some instabilty.
I'm gonna have to say that it will probalby work just fine.
Just don't expect to overclock at all anymore.
I've seen caps in worse shape than that work for years. I'd thing all the freak-outs about it ruining your CPU are just paranoia.
If I was in your shoes xxballa, I'd just try it out and hope the motherboard works.
tru u got nohting to lose aight:)
Yeah Im gonna have another cap put on the board for about $25 bucks and call it a day. I am not sure if its broken or not but I would rather just put another one on than fry my chip.
