beklemmung
- Aug 24, 2009
I have the Powercolor 2gb 6950 with two heat pipes. I was unable to unlock using RBE as it's a non-reference card. I then did the following process:
Step 1) Download ATI Winflash: http://www.techpowerup.com/downloads..._2.0.1.13.html (The newest version has been reported to not work).
2) Install winflash in the root directory (i.e. C:\winflash)
3) Download the script to modify the bios and extract it: www.techpowerup.com/wizzard/Mod_BIOS_HD_6950.zip
4) If you have a BIOS switch, set it to the 1 position (switched towards the back of the card)
5) Run ATI Winflash, click "Save" to save your BIOS, be sure to make a copy of this and save it some where safe in case some thing goes wrong.
6) Make a copy of the saved BIOS and rename the copy to "original.bin"
7) Copy the "original.bin" file to the script folder "Mod_BIOS_HD_6950"
8) Execute the "run.bat" batch file
9) Look in the folder "Mod_BIOS_HD_6950" and copy the file "modded.bin" to the folder you installed ATI Winflash in (C:\winflash)
10) Open up the command prompt (Start->All Programs->Accessories) you may have to right click and run as administrator
11) Change to the ATI Winflash directory with the command "cd C:\winflash" or what ever directory you saved it in
12) Type "atiwinflash -unlockrom 0" (the "0" stands for the first PCIe card installed, "1" will work for the 2nd card)
13) Type "atiwinflash -f -p 0 modded.bin" (the "0" stands for the first PCIe card installed, "1" will work for the 2nd card)
When I rebooted, Windows loaded but within about 3 seconds my screen artifacted and a few seconds later BSODed. I have a dual bios switch, so I shut down, flipped it to the other position (closer to the CF bridge) and logged in to Windows again, but got the same result.
I then flipped the bios switch back to the original position (away from the CF bridge), booted in to safe mode and uninstalled the card using device manager. Restarted again, booted in safe mode, and followed steps 10-13 above but used a previously saved copy of the original bios that I copied in to my Winflash folder (and substituted "original.bin" for "modded.bin"). I got a message stating that the bios successfully flashed.
However, whenever I boot Windows normally, I get the same result - near instant artifacting and then a BSOD. Once it recovered for a few seconds after artifacting, and Windows told me the display driver had recovered, but then it immediately artifacted and BSODed again.
I'm typing this in safe mode with networking enabled and I don't have any issues. However, if I boot Windows normally with the bios switch in either position, it will artifact and BSOD near instantly. Any suggestions?
