DiamondMax 10 Problems with VIA VT8237 Chipset
coold8
Hi, I just bought a DiamondMax 10 300gb 16mb Cache SATA Drive. I have a VIA VT8237 SATA controller (SATA I). When I plug it into the board it does not recognize the drive and just skips off the SATA check. When I move the drive over to my Silicon Image 680 Controller I no longer have that problem and it recognizes the drive. When I plug an alternate drive into the VIA controller it detects it fine. I noticed there is one jumper on the back of the drive, I am not sure what it sets, but could that be the problem? Thanks for your help.
http://www.behardware.com/news/imprimer/7717/
Try going to VIA's website and grabbing the latest drivers for everything, including the SATA controller on the south bridge. If you have the newest Diamondmax 10's (that are SATA2/300mb per sec) then they won't work unless you install some kind of update... if it's available at all.
