DIAMOND Viper HD3850 $49.99 AR
You always have to follow up with Diamond to get the rebate. Too much hassle for me. I did 2 of those rebates this year and each took a long time to finally get paid.
not bad at all, not sure about the cooler on that thing though. but 50 dollars for a 3850 is as good if not better deal then the 9600GSO.
just curious.. 9600gso or 3850?
The new 48SP 9600GSO (256/512MB) is slower. The old 9600GSO (same as 8800GS) with 384MB is mixed, depending on the game.
http://en.expreview.com/2008/01/21/review-palit-8800gs-384mb-768mb.html?page=24
It seems 8800GS 384MB lose in this comparison, but when we omit the low FPS score, 8800GS 384MB outperforms HD 3850 512MB about 7%.
Without the unplayable scores, the 8800GS/9600GSO is faster on average.
Neither is a bad card for $50, but both rebates are not ideal. The evga at TD isn't a manufacturer's rebate (evga manufacturer rebates are awesome), and Diamond is very slow and requires follow up. bleh
That comparison is at near stock settings on the 8800gs/9600gso (575/1700). Most 8800gs's (at least the EVGA variety) max out at 700/2000, roughly a 25% OC.
I've had the card for a year, the stock fan always runs at 100% and cannot be controlled in riva tuner. It's a normal 80x15mm fan so I replaced it with another fan with the normal 3 pins. Runs at 40c idle and 55 on load with the new quiet fan, was 5c cooler before.
