Hi everyone,
Thanks for reading this. I built a small computer for a friend back in April. It seemed to be just fine for a while but then a few issues crept up. The computer wouldn't shut down for about a week. Then that went away. A few days after it wouldn't turn on at all except that the keyboard connected to the PS/2 port flashed on briefly. It still exhibits this behavior.
I've checked the motherboard connections, all of which were secure. I swapped out the power supply for another one I know works and the same thing happened. My hunch is that the motherboard is the culprit but am hoping for other ideas I may have overlooked. In case it helps, here is the component list.
Processor: Intel Core i3-4330
Motherboard: ASRock H97M-ITX/ac LGA 1150 Intel H97
Power supply: SILVERSTONE ST45SF-G 450W SFX12V Modular
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) 240-Pin DDR3 1600
Optical drive: SAMSUNG 8x Internal Slim DVD Burner SN-208FB/BEBE
Storage: Crucial BX-100 500GB
Case: LIAN LI PC-TU100A Silver Aluminum Mini-ITX Tower
Operating System: Windows 8.1
Any input is greatly appreciated. We're hoping to fix this to make it an awesome portable gaming box by adding a video card, likely a GTX 960.
