DHCP & Wireless Questions
AndyT_uk
Evening all,
Just a quick and hopefully easy question regarding DHCP.
If you setup a new scope how do you get a certain group of clients (say wireless clients) to use that scope?
Basically i'm extending our wireless at work into another office. They'll have there own DHCP server over there but after going through the configs for our existing cisco AP's/WDS/WLSE and ACS boxes I can't find any reference to the DHCP server that the clients pickup when they connect to the wireless.
Is it likely to be a switch configuration or have i just missed it in the wireless kit configs?
Actually... it would be the same for it we put a new wired network in with its own DHCP scope... I assume then the switches get configured to look at a particular DHCP server but how does it know which scope to use?
Cheers for any help... Think i've actually confused myself with that.. especially with it being the end of the week :p
