[BB] Rick James
[H]ard Dawg
- Apr 4, 2004
The server will hand out an IP address and allow data to pass through, but when you go into the DHCP manager and look at hte address leases it's handed out, none are showing up.
I'll assume it's a W2k3 / W2k server. If so, is the little icon next to DHCP green or red. Green is activated.....red is stopped.
If it's red...just right click and fire away.
Just for grins have you done an ipconfig /all from a client to verify?
If it does show the server as the DHCP server then you may be need to reinstall the DHCP components in your server.
Well there is your problem. Have you identified what device is acting as a DHCP server?
Definitely check around and make sure someone hasn't installed rogue equipment that you have not approved (wireless access points often are the cause of this).
