Ther desktop I am using seems to be reqiuring me to use DHCP. I am behind a router (linksys), XPPro SP1, onboard LAN (IC7-G), and double-checked the subnet and first 3 groups in IP to make sure they match. Now running under a dynamic ip works, but I have a tendency to opt for the more difficult of situations, so I want static. Static used to work just fine and now it doesn't. No clue what has changed since then.
well, if the opposite were true, first thing I would do is open up the services.msc and go snooping around in there for anything DHCP; but since that is not the case, I don't know where to start.
Anybody have an idea on where I should start ? ?
