Hi All,
I have an SBS 2008 network to which I need to add 2 subnets for iSCSI.
The subnets will be 192.168.10.0/28 and 192.168.11.0/28.
SBS 2008 can only have one NIC so I have installed DHCP on the iSCSI file server which will be connected to the iSCSI array. This DHCP server is bound to the 2 iSCSI NICs but not to the production LAN connected NIC.
Now as soon as I authorise the new DHCP server the SBS 2008 DHCP service stops. This is apparently by design as a protection against rogue DHCP servers. So I now plan to have a router between the subnets, apparently DHCP requests cannot be routed. I'd like to check the sanity of the design as I am no expert.
The iSCSI file server running the secondary DHCP, purely to serve IP addresses to the iSCSI subnets, has 3 NICs. 192.168.3.x/24 (production LAN), 192.168.10.x/28 (iSCSI LAN_01) 192.168.11.x/28 (iSCSI LAN_02).
The new router (pfsense) will need 3 NICs. 1 x 192.168.3.x/24 , 1 x 192.168.10.x/28, 1 x 192.168.11.x/28. That way the server will be able to connect to the production LAN and the iSCSI subnets but DHCP requests will not "escape' onto the production LAN.
All of these servers are virtualised under ESXi so the hardware costs are negligible, a little RAM and some CPU cycles.
All comments and criticisms are always welcome.
Cheers.
Cheers.
