Shadowspawn
- Sep 17, 2002
Calling all network administrators; I've got an issue that is driving me up the wall.
I have just completed standing up an AN-30 LOS shot to a remote building. Each end has a Cisco 2851 router and I have built a GRE tunnel between the two as part of the security. Naturally there are other parts to this network but I am most concerned with the tunnel as I believe it is the source of the isse.
The link is active and appears to be fully capable of passing traffic however the DHCP requests coming from the two VLANs on the distant end appear to be corrupted when passing through the tunnel. I am running Netflow Scrutinizer on the distant end of the link and can see the the requests coming from the VLAN gateways and I can see the replies coming from the DHCP server however none of the phones/computers receive IPs and the DHCP server never shows the leases.
I know the issue is not a routing problem as pings to the server sourced from the VLAN gateways work perfectly as well as my ability to SSH into the remote router and switch.
During testing the DHCP server displayed two entries that appeared to be corrupt: mishapen MAC addresses and system names.
I have not added any statements to the tunnel other than the bandwidth (2048). If anybody out there has had experience with this sort of issue I would appreciate the input. This problem is going to drive me nuts and the customer has been waiting too long already.
Thanks,
Brian
Thanks,
Brian
