dg33tl
ivesceneenough
i have one of these laying around. i am considering using it for a HTPC build.
the board is new in box, about 2 years old. it says it supports the q9550 with more recent BIOS updates.
if the older BIOS doesnt support the chip, will it work? or do i need to pull my q6700 from another rig and use it to flash the BIOS then use the q9550?
if the older bios doesn't support the chip, you will have to pull the q6700 from another rig to flash it
