DFI x38 vs P35
If I had to choose between just those two then I would go with the X38 since it is only $30 difference. However, you should check out the Gigabyte GA-EX38-DS4. If you can live with "only" six SATA ports (completely powered by the ICH9R), then this board is a lot better value.
I am starting to like the DFI boards and might get one but that price for a P35 looks bad.
I like my DFI, runs real well, however I am waiting for my x48 DFI to show on friday :)
Larry
What I like about that Gigabyte is that it has 8 USB ports on the back I/O panel. What I don't like about it is it looks like a kindergartener's coloring book.
The DFIs look way sexier with their all black/green color scheme but I would never pay $200+ for a mainboard. I would stick with a DK version.
i had the p35 lp ut and got 4300 with my e8400, so i am going to have to give that one the vote. the lp lt is the same board, with slightly different cooling, and no thermopiper thingie, which nobody uses anyway. and the p35 lp's are 2 of the extremely rare boards that let you disable vdroop in bios. the dfi x38 might also, but not sure.
