DFI UT LP Ultra-D
gotfrag?
got a question
do all the newest DFI UT LP Ultra-D's come with the proper bios for the X2?
like if i bought one form monarch then can i plug and play, without having to find a way to flash?
I think at this point all the boards have at least BIOS version 3/10/05, which doesn't support dual core CPUs out of the box. You will be able to boot the board with the X2 and everything, but I think it'll only recognize one core. Official BIOS version 6/23 includes support for dual core. That requires a floppy drive or Winflash though.
If you want to use a bootable BIOS CD, I recommend this one. You have to burn it (here's a guide just in case), you just stick it in your CDROM drive and reset the computer. If you're using the stock BIOS settings, it'll boot right into the main menu. You'd want to select option three from the main menu, and then I recommend using OCZ Tony's 704-BTA BIOS (the first option). It's easily the best DFI LP NF4 BIOS out right now. It supports dual core too.
