dfi ultra infinity vs. abit nf7-s
I'm debating between these two mobo's, i'm also gonna be getting a mobile athlon 2500+ in hopes to oc a bit. Which is better? Also, will getting them refurbished off of newegg hurt me at all?
Thanx in advance!
The DFI seems to be much more reliably attaining ultrahigh front side bus speeds (>230MHz), but may have a somewhat higher DOA rate.
I would personally buy the DFI in part because of the FSB speeds it readily attains, as well as the digital input and output and 4 channels of (Silicon Image 3114) SATA rather than two.
i would also recomend the DFI over Abit's
FSB OCing is the easiest way to go and DFI has the capability to help u get those high clocks
