DFI Ultra Infinity Manual (Optical Header?)
Spare-Flair
Hey, can the people who own the DFI Ultra Infinity nForce 2 check their manuals for me and verify if the header on the lower left corner of the board is an Optical S/PDIF header?
This diagram only says it's an S/PDIF header but I don't know if it's coaxial (which makes no sense since there are already coax in and out on the back panel) or optical.
Does the manual say what part or accessory I need (like a bracket or a riser board) in order to make use of this? I really need to have Optical SPDIF for a board and for audio production and this is the best candidate so far.
DFI's own accessory page is down so I can't find any information on it.
http://www.dfi.com.tw/Product/xx_accessories.jsp
I apologize for starting a separate thread about this but I really need to know as soon as possible because I need a new system very soon.
For those that aren't sure what I'm talking about, the two ports on the back are coaxial S/PDIF in and out:
They are like RCA plugs but carry digital sound.
What I need is an optical S/PDIF which is usually a black square plug and carries the digital sound signal via light in fibre-optic cable. It's the plug seen on the bracket in the bottom right of this picture.
This is the bracket for a Pine board which is not what I need. I need info on what sort of bracket or expansion card the DFI Ultra Infinity uses and where I can buy one if indeed the header is an S/PDIF optical. The only bracket the DFI board comes with is a firewire port.
Thanks.
-Jeremy
A couple of things:
Do you need optical out or optical in?
The header in this case is probably not an input.
I'd suggest you invest in a proper soundcard with multiple ADC's if you plan on doing audio production. Buy a cheaper motherboard and add a card, sell some blood, search for change in your couch. Do whatever it takes, your recordings will sound all the better for it.
If you just need the optical-out capability most optical out headers should work. SPDIF is the protocol, it doesnt change depending on the means of transfer (optical or coaxial digital). If the header has the same number of pins as the bracket, it should work.
There is another consideration however.
Since the DFI Ultra Infinity board uses the craptastic ALC650 CODEC for audio I/O chores, it almost assuredly resamples all digital output to 48KHz unless it is already at that frequency to begin with (CD audio is at 44.1).
There exists one motherboard that not only features native optical digital I/O capabilities, but uses a CODEC which does not resample it's digital output. That board is the Abit AN7, which will probably not overclock as well as the DFI.
Again, for music production I'd suggest investing in a specialized card that can handle digital and analog input and has superior sound quality characteristics to the onboard CODECs you find on all motherboards.
Someone needs to integrate a VIA Envy24 onboard and mate the front channel output and the inputs with a quality DAC and not a craptastic CODEC. Albatron tried, but ended up using an expensive Wolfson DAC for the effects channel output and a CODEC for the front and as the ADC.
