DFI Ultra-D + WinXP issue
SRT-4
Somewhat of a silly issue/problem, but I have a DFI Ultra-D/WinXP SP2 and a 36GB WD Raptor SATA drive on SATA1.
Thing I've noticed is that the Raptor harddrive is showing in the taskbar as "Safely remove hardware" like it's noticing it's plug and play. Well, it's not as I have WinXP installed on it! Any ideas? Only thing I can think of is that under device manager, I have a "Unknown Device" under "Other devices". Location says "On PCI bus" but the WD Raptor is listed just fine under device manager.
Anyone have this problem???
TIA
SATA hard drives are hotswappable like USB flash drives so it's showing up like that. XP just isnt smart enough to realize the OS is running off the removable drive so lists it under the removable hardware tab.
I doubt thats what its talking about, I have a raptor and it didnt do that. Have you got the latest drivers for your mobo?
Mine did that for a couple boots and then stopped. I flashed the BIOS at some point so it may have been what fixed it, don't know don't care. It's gone now.
