DFI P45 T2RS
Eibach
So i just got this mobo the other day and tried to set it up in my new computer and it would not post. It had a very weird diagnostic code that i have never seen before it was not normal characters it as like half of a 7 and half of a 0, do you think that his is a DOA???
I've read that the mobo is very picky. Some people have reported issues with their ram and the mobo.
I suggest you contact DFI to see if there might be a work around.
I have a DFI P35 and it's been great. Easy OCer
i have that motherboard. if you are ever able to post, flash the bios with 7/09. mine was very flaky until i flashed. by any chance, are you using the bottom pcie slot?
just from my experience it seems that DFI boards are very fragile. I've had the DFI lan party nf4 board and the LP DK P35 board and both had the same problems. Set it up at first and they worked like a champ. If I did some tinkering or changed some piece of hardware and put it back together, it would not post. 24hr cmos reset and still notta. I'm staying away from DFI from here on out. I really wanted to like their boards b/c of the plethora of tweaking options but if it's going to be that picky or fragile with my other components then I'll use something else. and it's not like i'm using a cheap psu or value ram.
thanks for all the help guys, i think i will try to reset the cmos and see if that changes anything.... i am not able to post so i cannot flash the bios. if that does not work i will be RMA ing it
